The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
application.volume events
Creating your file...
Your file is ready
application.volume.removed
- Severity
ERROR
- Description
This message occurs when an application is destroyed, but a member volume was not deleted after an error was was encountered. This volume is no longer associated with the application and must be deleted manually.
- Corrective Action
Delete the volume using the "volume delete" command.
- Syslog Message
Failed to destroy member volume %s in Vserver %s during an application destroy operation. The volume must be deleted manually. The volume was previously associated with an application with UUID %s.
- Parameters
volumeName (STRING): Name of the volume.
vserver (STRING): Vserver containing the volume.
applicationUUID (STRING): UUID of the application.
