ONTAP EMS reference
ccma.disabled events
ccma.disabled
Severity
ERROR
This message occurs when the Performance Archive has been disabled for more than an hour. This is caused by setting the -is-enabled flag to false. This message will be repeated every hour that the archiver is turned off. The messages will only displayed once a day.
Corrective Action
Run the 'statistics archive config modify -is-enable true' command. This will enable the Performance Archive.
Syslog Message
The Performance Archive has been disabled for more than an hour. It is Important for the analysis and diagnoses of performance related issues. Consider enabling it.
(None).
Looking for answers?
Try Doc, our Gen AI Assistant.
