ONTAP EMS reference
master.cast events
master.cast EMS events occur when ONTAP encounters issues associated with casting votes on the connection status of the cluster master.
master.cast.cm.vote.against
Severity
NOTICE
This message occurs when the master service of the associated node can not connect to current cluster master and try to cast a vote against current cluster master in the global database. The current cluster master will be demoted if more than half of the cluster nodes vote against it, and a new cluster master will be promoted.
Corrective Action
(None).
Syslog Message
Service ID "%u" on node ID "%u" has voted against current cluster master with sequence number "%u" based on "%s", the current MVIP connection state is %s with duration %s, and the best connection state is %s.
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
sequenceNumber (INT): The sequence number of the cluster master.
reason (STRING): The reason for casting the vote against current cluster master.
currentState (STRING): The current MVIP connection state.
currentStateDuration (STRING): The duration of current MVIP connection state.
highestState (STRING): The best MVIP connection state since the node connects to current cluster master.
master.cast.cm.vote.ex
Severity
NOTICE
This message occurs when the master service on the associated node is unable to cast a vote to update the connection status with current cluster master in global database since it has lost connection to the database server.
Corrective Action
(None).
Syslog Message
Service ID "%u" on node ID "%u" failed to cast a vote to cluster master with sequence number is "%u" due to exception (%s). The connection state is %s with duration %s, and the best connection state is %s.
sequenceNumber (INT): The sequence number of current cluster master.
exceptionCode (STRING): The exception code.
