fmmb.current events
fmmb.current.lock.disk
Severity
INFORMATIONAL
This event is issued when HA mailbox disks are discovered or allocated.
Corrective Action
(None).
Syslog Message
Disk %s is a %s HA mailbox disk.
disk (STRING): The name of the disk. If the disk name is not available, the name ?.? will be used.
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
