The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fmmb.current events
Creating your file...
Your file is ready
fmmb.current.lock.disk
- Severity
INFORMATIONAL
- Description
This event is issued when HA mailbox disks are discovered or allocated.
- Corrective Action
(None).
- Syslog Message
Disk %s is a %s HA mailbox disk.
- Parameters
disk (STRING): The name of the disk. If the disk name is not available, the name ?.? will be used.
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
