The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
dfu.badbridgeshelfconfig events
Creating your file...
Your file is ready
dfu.badBridgeShelfConfig
- Severity
ERROR
- Description
This message occurs when the disk firmware update aborts because it cannot contact the two peer FC-to-SAS bridges.
- Corrective Action
Make sure that the storage controller is correctly cabled to the two peer FC-to-SAS bridges and that the bridges are correctly cabled to the SAS disk shelves. Then retry the 'disk_fw_update' command.
- Syslog Message
Error contacting two peer FC-to-SAS bridges. Unable to download firmware to disk %s [%s %s %s] S/N [%s].
- Parameters
diskName (STRING): Name of the disk.
vendorName (STRING): Vendor name of the disk.
productId (STRING): Product ID of the disk.
fwVersion (STRING): Firmware version of the disk.
serialno (STRING): Serial number of the disk.
