The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
siw.cpubindingfailed events
Creating your file...
Your file is ready
siw.cpuBindingFailed
- Severity
ERROR
- Description
This message occurs when the system fails to bind a SW-iWARP thread to a CPU during the boot-up. If this happens, SW-iWARP cannot support polling and will be running in a degraded state.
- Corrective Action
Try a takeover and giveback of both of the nodes. If it still fails, contact NetApp technical support.
- Syslog Message
SW-iWARP thread could not be bound to a CPU because: "%s".
- Parameters
reason (STRING): Reason for the CPU binding failure
