gpo.reg events
Creating your file...
gpo.reg.applied
- Severity
INFORMATIONAL
- Description
This message occurs when the group policy object (GPO) registry policy settings are applied.
- Corrective Action
(None).
- Syslog Message
Successfully applied GPO registry settings to Vserver %s.
- Parameters
vserver (STRING): Vserver name.
gpo.reg.bCache.applied
- Severity
INFORMATIONAL
- Description
This message occurs when the group policy object (GPO) BranchCache settings are applied.
- Corrective Action
(None).
- Syslog Message
Successfully applied BranchCache settings to Vserver %s.
- Parameters
gpo.reg.bCache.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) registry BranchCache policy settings fails.
- Corrective Action
Address the specific reason for the issue, and then apply the settings again by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
Failed to apply BranchCache settings for Vserver %s, reason: %s.
- Parameters
reason (STRING): Reason for the failure.
gpo.reg.notApplied
- Severity
ERROR
- Description
This message occurs when applying group policy object (GPO) registry policy settings fails.
- Corrective Action
- Syslog Message
Failed to apply GPO registry settings for Vserver %s, reason: %s.
- Parameters
