ONTAP EMS reference
gpo.reg events
gpo.reg EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) registry policy settings.
gpo.reg.applied
Severity
INFORMATIONAL
This message occurs when the group policy object (GPO) registry policy settings are applied.
Corrective Action
(None).
Syslog Message
Successfully applied GPO registry settings to Vserver %s.
vserver (STRING): Vserver name.
gpo.reg.bCache.applied
Severity
INFORMATIONAL
This message occurs when the group policy object (GPO) BranchCache settings are applied.
Corrective Action
(None).
Syslog Message
Successfully applied BranchCache settings to Vserver %s.
gpo.reg.bCache.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) registry BranchCache policy settings fails.
Corrective Action
Address the specific reason for the issue, and then apply the settings again by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
Failed to apply BranchCache settings for Vserver %s, reason: %s.
reason (STRING): Reason for the failure.
gpo.reg.notApplied
Severity
ERROR
This message occurs when applying group policy object (GPO) registry policy settings fails.
Corrective Action
Syslog Message
Failed to apply GPO registry settings for Vserver %s, reason: %s.
