ONTAP EMS reference
ha.takeover events
ha.takeover EMS events occur when ONTAP encounters issues associated with high-availability (HA) takeover operations.
ha.takeover.bypOptimChange
Severity
INFORMATIONAL
This message occurs when the value of the 'bypass-takeover-optimization' parameter of the "storage failover" command is changed on a node.
Corrective Action
(None).
Syslog Message
(None).
node_name (STRING): Name of the node.
new_value (STRING): New value of the 'bypass-takeover-optimization' parameter.
ha.takeover.checkEnd
Severity
ALERT
This message occurs when a node is simulating a takeover. This marks the end of a simulated takeover on the local node.
Corrective Action
(None).
Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has ended on the local node.
(None).
ha.takeover.checkError
Severity
ALERT
This message occurs when a takeover with the check-only flag detects an error that would prevent takeover.
Corrective Action
Use the "storage failover check-takeover" command to identify the failures that occured along the takeover path. Perform corrective action based on error information shown by the command.
Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has encountered and error that would disrupt takeover.
(None).
ha.takeover.checkStart
Severity
ALERT
This message occurs when a node is simulating a takeover. This marks the start of a simulated takeover on the local node.
Corrective Action
(None).
Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has started on the local node.
(None).
