ONTAP EMS reference
cluster.repl events
cluster.repl.localNW.unreachable
Severity
NOTICE
This message occurs when the cluster replication heartbeat to a peer cluster cannot reach the local management gateway process for a minimum of 300 seconds. This potentially affects MetroCluster(tm) and Vserver disaster recovery (DR) applications.
Corrective Action
(None).
Syslog Message
The cluster replication heartbeat could not reach the local management gateway process for at least %d seconds.
durationSinceLastSuccess (INT): Number of seconds since the problem first occurred.
cluster.repl.peer.reachable
Severity
NOTICE
This message occurs when the cluster replication heartbeat can now reach the peer cluster, after previous failures resulted in raising one of the following events: cluster.repl.localNW.unreachable, cluster.repl.peerNW.unreachable, or cluster.repl.remoteApp.unreachable.
Corrective Action
(None).
Syslog Message
The cluster replication heartbeat can now reach peer cluster %s.
peerIPaddress (STRING): Peer cluster IP address that can now be reached.
Severity
ALERT
This message occurs when the cluster replication heartbeat to the peer cluster fails for a minimum of 300 seconds. This potentially affects MetroCluster(tm) and Vserver disaster recovery (DR) applications.
Corrective Action
Verify network connectivity between the local cluster and the peer cluster. Check the cluster peer EMS messages for more information.
Syslog Message
The cluster replication heartbeat to peer cluster %s failed for at least %d seconds.
peerIPaddress (STRING): Cluster peer IP address that could not be reached.
Severity
ALERT
This message occurs when the cluster replication heartbeat to the remote cluster replication application fails for a minimum of 300 seconds. This potentially affects MetroCluster(tm) and Vserver disaster recovery (DR) applications.
Corrective Action
Check the state of the replication application process running on the peer cluster by issuing the 'cluster ring show -unitname crs' command.
Syslog Message
The cluster replication heartbeat to the remote application running on peer cluster %s failed for at least %d seconds.
peerIPaddress (STRING): Remote application cluster IP address that could not be reached.
