cluster.repl events
Creating your file...
cluster.repl.localNW.unreachable
- Severity
NOTICE
- Description
This message occurs when the cluster replication heartbeat to a peer cluster cannot reach the local management gateway process for a minimum of 300 seconds. This potentially affects MetroCluster(tm) and Vserver disaster recovery (DR) applications.
- Corrective Action
(None).
- Syslog Message
The cluster replication heartbeat could not reach the local management gateway process for at least %d seconds.
- Parameters
durationSinceLastSuccess (INT): Number of seconds since the problem first occurred.
cluster.repl.peer.reachable
- Severity
NOTICE
- Description
This message occurs when the cluster replication heartbeat can now reach the peer cluster, after previous failures resulted in raising one of the following events: cluster.repl.localNW.unreachable, cluster.repl.peerNW.unreachable, or cluster.repl.remoteApp.unreachable.
- Corrective Action
(None).
- Syslog Message
The cluster replication heartbeat can now reach peer cluster %s.
- Parameters
peerIPaddress (STRING): Peer cluster IP address that can now be reached.
- Severity
ALERT
- Description
This message occurs when the cluster replication heartbeat to the peer cluster fails for a minimum of 300 seconds. This potentially affects MetroCluster(tm) and Vserver disaster recovery (DR) applications.
- Corrective Action
Verify network connectivity between the local cluster and the peer cluster. Check the cluster peer EMS messages for more information.
- Syslog Message
The cluster replication heartbeat to peer cluster %s failed for at least %d seconds.
- Parameters
peerIPaddress (STRING): Cluster peer IP address that could not be reached.
- Severity
ALERT
- Description
This message occurs when the cluster replication heartbeat to the remote cluster replication application fails for a minimum of 300 seconds. This potentially affects MetroCluster(tm) and Vserver disaster recovery (DR) applications.
- Corrective Action
Check the state of the replication application process running on the peer cluster by issuing the 'cluster ring show -unitname crs' command.
- Syslog Message
The cluster replication heartbeat to the remote application running on peer cluster %s failed for at least %d seconds.
- Parameters
peerIPaddress (STRING): Remote application cluster IP address that could not be reached.
