The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.encryptcmdfailed events
Creating your file...
Your file is ready
disk.encryptCmdFailed
- Severity
ERROR
- Description
This message occurs when the indicated "storage encryption disk" command fails on an encrypting disk that supports storage encryption methods.
- Corrective Action
Verify that storage encryption key servers, if required, are available and functioning, or that expected on-board keys are present.
- Syslog Message
Encrypting disk %s failed disk encrypt %s command with error status %s (0x%x).
- Parameters
disk (STRING): Name of the disk.
command (STRING): Storage encryption disk command.
error_string (STRING): Error status code description.
error (INT): Error status code.
