disk.encryptcmdfailed events
Creating your file...
Your file is ready
disk.encryptCmdFailed
- Severity
ERROR
- Description
This message occurs when the indicated "storage encryption disk" command fails on an encrypting disk that supports storage encryption methods.
- Corrective Action
Verify that storage encryption key servers, if required, are available and functioning, or that expected on-board keys are present.
- Syslog Message
Encrypting disk %s failed disk encrypt %s command with error status %s (0x%x).
- Parameters
disk (STRING): Name of the disk.
command (STRING): Storage encryption disk command.
error_string (STRING): Error status code description.
error (INT): Error status code.
