ONTAP EMS reference
disk.encryptcmdfailed events
disk.encryptcmdfailed EMS events occur when the indicated "storage encryption disk" command fails on an encrypting disk that supports storage encryption methods.
disk.encryptCmdFailed
Severity
ERROR
This message occurs when the indicated "storage encryption disk" command fails on an encrypting disk that supports storage encryption methods.
Corrective Action
Verify that storage encryption key servers, if required, are available and functioning, or that expected on-board keys are present.
Syslog Message
Encrypting disk %s failed disk encrypt %s command with error status %s (0x%x).
disk (STRING): Name of the disk.
command (STRING): Storage encryption disk command.
error_string (STRING): Error status code description.
error (INT): Error status code.
