ONTAP EMS reference
mgwd.notify events
mgwd.notify.halt.result
Severity
INFORMATIONAL
This message reports the result of the Management Gateway process notification attempt to the Connectivity, Liveliness, Availability Monitor (CLAM) instance on its high-availability (HA) partner node that this node is undergoing a planned shutdown.
Corrective Action
(None).
Syslog Message
MGWD %s to notify CLAM on its HA partner node that this node is undergoing a planned shutdown (reason: %s). Error: %s
result (STRING): Result of the notify attempt.
reason (STRING): Reason for the partner beginning the halt process.
error (STRING): Error encountered in the notify attempt (if any).
