The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgwd.notify events
Creating your file...
Your file is ready
mgwd.notify.halt.result
- Severity
INFORMATIONAL
- Description
This message reports the result of the Management Gateway process notification attempt to the Connectivity, Liveliness, Availability Monitor (CLAM) instance on its high-availability (HA) partner node that this node is undergoing a planned shutdown.
- Corrective Action
(None).
- Syslog Message
MGWD %s to notify CLAM on its HA partner node that this node is undergoing a planned shutdown (reason: %s). Error: %s
- Parameters
result (STRING): Result of the notify attempt.
reason (STRING): Reason for the partner beginning the halt process.
error (STRING): Error encountered in the notify attempt (if any).
