mgwd.notify events
mgwd.notify EMS events occur when this message reports the result of the Management Gateway process notification attempt to the Connectivity, Liveliness, Availability Monitor (CLAM) instance on its high-availability (HA) partner node that this node is undergoing a planned shutdown.
mgwd.notify.halt.result
- Severity
INFORMATIONAL
- Description
This message reports the result of the Management Gateway process notification attempt to the Connectivity, Liveliness, Availability Monitor (CLAM) instance on its high-availability (HA) partner node that this node is undergoing a planned shutdown.
- Corrective Action
(None).
- Syslog Message
MGWD %s to notify CLAM on its HA partner node that this node is undergoing a planned shutdown (reason: %s). Error: %s
- Parameters
result (STRING): Result of the notify attempt.
reason (STRING): Reason for the partner beginning the halt process.
error (STRING): Error encountered in the notify attempt (if any).
