ONTAP EMS reference
netif.toomanynics events
netif.toomanynics EMS events occur when a network interface was not initialized because the number of interfaces of this type exceeds the maximum supported.
netif.tooManyNics
Severity
ERROR
This message occurs when a network interface was not initialized because the number of interfaces of this type exceeds the maximum supported.
Corrective Action
Remove a network interface card (NIC).
Syslog Message
Network interface %s was not initialized because the number of interfaces of this type exceeds the maximum (%d) supported.
ifName (STRING): Name of the network interface; for example, "e8a".
maxIf (INT): Maximum number of interfaces of this type that is supported.
