netif.toomanynics events
Creating your file...
Your file is ready
netif.tooManyNics
- Severity
ERROR
- Description
This message occurs when a network interface was not initialized because the number of interfaces of this type exceeds the maximum supported.
- Corrective Action
Remove a network interface card (NIC).
- Syslog Message
Network interface %s was not initialized because the number of interfaces of this type exceeds the maximum (%d) supported.
- Parameters
ifName (STRING): Name of the network interface; for example, "e8a".
maxIf (INT): Maximum number of interfaces of this type that is supported.
