ONTAP EMS reference
disk.init events
disk.init EMS events occur when ONTAP encounters issues associated with disk initialization.
disk.init.badSectorSize
Severity
ERROR
This message occurs when a disk reports a sector size that does not match the drive qualification table.
Corrective Action
Replace the disk.
Syslog Message
Disk %s has an unexpected sector size (%d bytes) and cannot be used.
diskName (STRING): Name of the disk.
sector_size (INT): Invalid sector size.
disk.init.err.capacityFlash
Severity
ERROR
This message occurs when a capacity-optimized flash solid-state drive (SSD) is detected by a node that does not support this type of SSD.
Corrective Action
Remove the disk from the system.
Syslog Message
Disk %s cannot be used on a node that does not support capacity-optimized flash.
disk.init.err.flashOptimized
Severity
ERROR
This message occurs when a hard disk drive (HDD) is detected by a node configured with the All-Flash Optimized personality. With this personality, only solid-state drives (SSD) can be used.
Corrective Action
Syslog Message
Disk %s cannot be used on a node configured as All-Flash Optimized.
disk.init.err.unsupp.shelf
Severity
ERROR
This message occurs when an unsupported NVMe solid-state drive (SSD) is discovered in an external NVMe shelf. This NVMe SSD is only supported as an internal drive on the AFF A800 system.
Corrective Action
Remove the drive from the external NVMe shelf.
Syslog Message
Drive %s cannot be used in an external NVMe shelf.
disk_name (STRING): Name of the SSD.
disk_information (STRING): Formatted information about the SSD. This includes the drive's vendor, model, firmware revision, and serial number.
disk.init.err.unsupported
Severity
ERROR
This message occurs when an unsupported disk is detected on a node.
Corrective Action
Syslog Message
Disk %s is not recognized as a supported disk and cannot be used on this node.
disk.init.err.zns
Severity
ERROR
This message occurs when a zoned namespace solid-state drive (SSD-ZNS) is detected by a node that does not support this type of SSD.
Corrective Action
Syslog Message
Disk "%s" cannot be used on a node that does not support SSD-ZNS disks.
disk.init.error.capacity
Severity
ERROR
This message occurs when a disk reports an unexpected capacity.
Corrective Action
Replace the disk.
Syslog Message
Disk %s has an unexpected capacity (%llu sectors) and cannot be used. Replace it.
lastSector (LONGINT): Last sector of the disk.
productID (STRING): Product name of the disk.
disk.init.error.serialno
Severity
ERROR
This message occurs when the inquiry command does not return a valid serial number or device ID for the device. The device is failed during initialization.
Corrective Action
Replace the disk.
Syslog Message
Serial number or device ID not available for %s.
disk_name (STRING): Disk name.
page_code (INT): Page code that was sent.
error_pcode (INT): Page code received in error.
disk.init.failure.error
Severity
ERROR
This message occurs when a drive fails initialization. For NVMe drives, the returned error information is translated into the SCSI equivalent.
Corrective Action
Replace the drive.
Syslog Message
Drive %s failed initialization due to error %d, sense code(%x %x %x %x).
diskName (STRING): Name of the drive.
errorCode (INT): Internal E_SCSI return code.
sense_key (INTHEX): Sense key.
sense_code (INTHEX): Additional sense code.
qualifier (INTHEX): Additional sense code qualifier.
fru_failed (INTHEX): FRU code.
disk.init.failure.spinup
Severity
ERROR
This message occurs when a disk cannot spin up during initialization. The disk is marked as failed and is not used.
Corrective Action
Removed the disk from the system.
Syslog Message
Disk %s has failed to spin up and cannot be used. Replace it with a new drive.
disk.init.failureBytes
Severity
ERROR
This message occurs when the system discovers a previously failed disk. The system will not use the disk and it should be replaced.
Corrective Action
Replace the failed disk.
Syslog Message
Failed disk %s detected during disk initialization.
disk.init.invalidDDR
Severity
INFORMATIONAL
This message occurs when a disk contains a Dynamic Drive Recognition (DDR) label entry that is not for this disk. The system rewrites the DDR label with proper values.
Corrective Action
(None).
Syslog Message
Disk %s has an invalid DDR entry. DDR label will be corrected and rewritten automatically.
vendorID (STRING): Vendor name of the disk.
disk.init.prottype.incompat
Severity
ERROR
This message occurs when a hard disk drive (HDD) has a protection type enabled that is not supported. Protection type is a disk option that determines how information is physically saved on the disk.
Corrective Action
Syslog Message
Disk %s has protection type %x enabled and cannot be used. %s
protType (INTHEX): Value indicating the version of the enabled protection type.
disk_information (STRING): Formatted information about the disk. This includes the disk's vendor, model, firmware revision, and serial number.
disk.init.recognizedDDR
Severity
INFORMATIONAL
This message occurs when a Dynamic Drive Recognition (DDR) label on a drive with dynamically qualified data is properly updated with aliased data.
Corrective Action
(None).
Syslog Message
Disk %s has been updated with the proper drive name alias. The DDR label will be rewritten automatically.
disk.init.unknownDisk
Severity
ERROR
This message occurs when a unique identifier cannot be created for a disk due to internal disk problems.
Corrective Action
The disk needs to be replaced, remove it from the system.
Syslog Message
Unable to identify disk %s.
