disk.init events
disk.init.badSectorSize
- Severity
ERROR
- Description
This message occurs when a disk reports a sector size that does not match the drive qualification table.
- Corrective Action
Replace the disk.
- Syslog Message
Disk %s has an unexpected sector size (%d bytes) and cannot be used.
- Parameters
diskName (STRING): Name of the disk.
sector_size (INT): Invalid sector size.
disk.init.err.capacityFlash
- Severity
ERROR
- Description
This message occurs when a capacity-optimized flash solid-state drive (SSD) is detected by a node that does not support this type of SSD.
- Corrective Action
Remove the disk from the system.
- Syslog Message
Disk %s cannot be used on a node that does not support capacity-optimized flash.
- Parameters
disk.init.err.flashOptimized
- Severity
ERROR
- Description
This message occurs when a hard disk drive (HDD) is detected by a node configured with the All-Flash Optimized personality. With this personality, only solid-state drives (SSD) can be used.
- Corrective Action
- Syslog Message
Disk %s cannot be used on a node configured as All-Flash Optimized.
- Parameters
disk.init.err.unsupp.shelf
- Severity
ERROR
- Description
This message occurs when an unsupported NVMe solid-state drive (SSD) is discovered in an external NVMe shelf. This NVMe SSD is only supported as an internal drive on the AFF A800 system.
- Corrective Action
Remove the drive from the external NVMe shelf.
- Syslog Message
Drive %s cannot be used in an external NVMe shelf.
- Parameters
disk_name (STRING): Name of the SSD.
disk_information (STRING): Formatted information about the SSD. This includes the drive's vendor, model, firmware revision, and serial number.
disk.init.err.unsupported
- Severity
ERROR
- Description
This message occurs when an unsupported disk is detected on a node.
- Corrective Action
- Syslog Message
Disk %s is not recognized as a supported disk and cannot be used on this node.
- Parameters
disk.init.error.capacity
- Severity
ERROR
- Description
This message occurs when a disk reports an unexpected capacity.
- Corrective Action
Replace the disk.
- Syslog Message
Disk %s has an unexpected capacity (%llu sectors) and cannot be used. Replace it.
- Parameters
lastSector (LONGINT): Last sector of the disk.
productID (STRING): Product name of the disk.
disk.init.error.serialno
- Severity
ERROR
- Description
This message occurs when the inquiry command does not return a valid serial number or device ID for the device. The device is failed during initialization.
- Corrective Action
Replace the disk.
- Syslog Message
Serial number or device ID not available for %s.
- Parameters
disk_name (STRING): Disk name.
page_code (INT): Page code that was sent.
error_pcode (INT): Page code received in error.
disk.init.failure.error
- Severity
ERROR
- Description
This message occurs when a drive fails initialization. For NVMe drives, the returned error information is translated into the SCSI equivalent.
- Corrective Action
Replace the drive.
- Syslog Message
Drive %s failed initialization due to error %d, sense code(%x %x %x %x).
- Parameters
diskName (STRING): Name of the drive.
errorCode (INT): Internal E_SCSI return code.
sense_key (INTHEX): Sense key.
sense_code (INTHEX): Additional sense code.
qualifier (INTHEX): Additional sense code qualifier.
fru_failed (INTHEX): FRU code.
disk.init.failure.spinup
- Severity
ERROR
- Description
This message occurs when a disk cannot spin up during initialization. The disk is marked as failed and is not used.
- Corrective Action
Removed the disk from the system.
- Syslog Message
Disk %s has failed to spin up and cannot be used. Replace it with a new drive.
- Parameters
disk.init.failureBytes
- Severity
ERROR
- Description
This message occurs when the system discovers a previously failed disk. The system will not use the disk and it should be replaced.
- Corrective Action
Replace the failed disk.
- Syslog Message
Failed disk %s detected during disk initialization.
- Parameters
disk.init.invalidDDR
- Severity
INFORMATIONAL
- Description
This message occurs when a disk contains a Dynamic Drive Recognition (DDR) label entry that is not for this disk. The system rewrites the DDR label with proper values.
- Corrective Action
(None).
- Syslog Message
Disk %s has an invalid DDR entry. DDR label will be corrected and rewritten automatically.
- Parameters
vendorID (STRING): Vendor name of the disk.
disk.init.prottype.incompat
- Severity
ERROR
- Description
This message occurs when a hard disk drive (HDD) has a protection type enabled that is not supported. Protection type is a disk option that determines how information is physically saved on the disk.
- Corrective Action
- Syslog Message
Disk %s has protection type %x enabled and cannot be used. %s
- Parameters
protType (INTHEX): Value indicating the version of the enabled protection type.
disk_information (STRING): Formatted information about the disk. This includes the disk's vendor, model, firmware revision, and serial number.
disk.init.recognizedDDR
- Severity
INFORMATIONAL
- Description
This message occurs when a Dynamic Drive Recognition (DDR) label on a drive with dynamically qualified data is properly updated with aliased data.
- Corrective Action
(None).
- Syslog Message
Disk %s has been updated with the proper drive name alias. The DDR label will be rewritten automatically.
- Parameters
disk.init.unknownDisk
- Severity
ERROR
- Description
This message occurs when a unique identifier cannot be created for a disk due to internal disk problems.
- Corrective Action
The disk needs to be replaced, remove it from the system.
- Syslog Message
Unable to identify disk %s.
- Parameters
