The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sfu.rebootrequestfailure events
Creating your file...
Your file is ready
sfu.rebootRequestFailure
- Severity
ERROR
- Description
This message occurs when an attempt to issue a reboot request after downloading disk shelf firmware fails, indicating a software error.
- Corrective Action
Retry the (advanced privilege) "storage shelf firmware update" command.
- Syslog Message
Could not issue the request to reboot disk shelf %s.shelf%d module %s.
- Parameters
channelName (STRING): Name of the adapter port or switch port of the disk shelf to be rebooted.
shelfId (INT): ID of the disk shelf to be rebooted.
module (STRING): Module to be rebooted.
