sfu.rebootrequestfailure events
Creating your file...
Your file is ready
sfu.rebootRequestFailure
- Severity
ERROR
- Description
This message occurs when an attempt to issue a reboot request after downloading disk shelf firmware fails, indicating a software error.
- Corrective Action
Retry the (advanced privilege) "storage shelf firmware update" command.
- Syslog Message
Could not issue the request to reboot disk shelf %s.shelf%d module %s.
- Parameters
channelName (STRING): Name of the adapter port or switch port of the disk shelf to be rebooted.
shelfId (INT): ID of the disk shelf to be rebooted.
module (STRING): Module to be rebooted.
