ONTAP EMS reference
sfu.rebootrequestfailure events
sfu.rebootrequestfailure EMS events occur when an attempt to issue a reboot request after downloading disk shelf firmware fails, indicating a software error.
sfu.rebootRequestFailure
Severity
ERROR
This message occurs when an attempt to issue a reboot request after downloading disk shelf firmware fails, indicating a software error.
Corrective Action
Retry the (advanced privilege) "storage shelf firmware update" command.
Syslog Message
Could not issue the request to reboot disk shelf %s.shelf%d module %s.
channelName (STRING): Name of the adapter port or switch port of the disk shelf to be rebooted.
shelfId (INT): ID of the disk shelf to be rebooted.
module (STRING): Module to be rebooted.
