The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
monitor.temp events
Creating your file...
Your file is ready
monitor.temp.unreadable
- Severity
ERROR
- Description
This message occurs when the controller module temperature is not readable. In this condition, the system does not automatically shut down if it becomes too hot for reliable operation.
- Corrective Action
Shut down the system and power-cycle the controller module. If the temperature is still not readable, replace the controller module.
- Syslog Message
The controller temperature (%s) is not readable.
- Parameters
sensor_name (STRING): Sensor name.
