ONTAP EMS reference
monitor.temp events
monitor.temp.unreadable
Severity
ERROR
This message occurs when the controller module temperature is not readable. In this condition, the system does not automatically shut down if it becomes too hot for reliable operation.
Corrective Action
Shut down the system and power-cycle the controller module. If the temperature is still not readable, replace the controller module.
Syslog Message
The controller temperature (%s) is not readable.
sensor_name (STRING): Sensor name.
