      monitor.temp events
monitor.temp.unreadable
- Severity
ERROR
 - Description
This message occurs when the controller module temperature is not readable. In this condition, the system does not automatically shut down if it becomes too hot for reliable operation.
 - Corrective Action
Shut down the system and power-cycle the controller module. If the temperature is still not readable, replace the controller module.
 - Syslog Message
The controller temperature (%s) is not readable.
 - Parameters
sensor_name (STRING): Sensor name.
