monitor.temp events
Creating your file...
Your file is ready
monitor.temp.unreadable
- Severity
ERROR
- Description
This message occurs when the controller module temperature is not readable. In this condition, the system does not automatically shut down if it becomes too hot for reliable operation.
- Corrective Action
Shut down the system and power-cycle the controller module. If the temperature is still not readable, replace the controller module.
- Syslog Message
The controller temperature (%s) is not readable.
- Parameters
sensor_name (STRING): Sensor name.
