ONTAP EMS reference
fabricpool.full events
fabricpool.full
Severity
ERROR
This message occurs when the total, cluster-wide FabricPool space usage of object stores from capacity-licensed providers has reached the license limit.
Corrective Action
To find the percentage of the licensed capacity used by each FabricPool, use the "storage aggregate object-store show-space" command. To create more space, delete Snapshot(tm) copies from volumes with the tiering policy "snapshot" or "backup" by using the "volume snapshot delete" command. To increase the licensed capacity, install a new license on the cluster.
Syslog Message
Total, cluster-wide FabricPool space usage of object stores from capacity-licensed providers has reached the licensed limit. Cluster ID: %s. Current usage: %s, licensed capacity: %s.
cluster_uuid (STRING): UUID of the cluster.
used_capacity (STRING): Total usage of capacity-licensed object stores.
licensed_capacity (STRING): FabricPool licensed capacity.
