ONTAP EMS reference
asup.smtp events
asup.smtp EMS events occur when ONTAP encounters issues associated with the AutoSupport mechanism delivering email messages via SMTP.
asup.smtp.drop
Severity
ERROR
This message occurs when the AutoSupport® mechanism drops email messages after having retried for the specified times.
Corrective Action
Use the "system node autosupport check show-details" command to check for connectivity errors with the configured mailhost. If the connectivity check shows no errors and if the problem persists, contact NetApp technical support for further assistance.
Syslog Message
AutoSupport mail (%s) was not sent. The system will drop the message.
subject (STRING): AutoSupport message title.
