asup.smtp events
Creating your file...
Your file is ready
asup.smtp.drop
- Severity
ERROR
- Description
This message occurs when the AutoSupport® mechanism drops email messages after having retried for the specified times.
- Corrective Action
Use the "system node autosupport check show-details" command to check for connectivity errors with the configured mailhost. If the connectivity check shows no errors and if the problem persists, contact NetApp technical support for further assistance.
- Syslog Message
AutoSupport mail (%s) was not sent. The system will drop the message.
- Parameters
subject (STRING): AutoSupport message title.
