ONTAP EMS reference
air.disable events
air.disable.async.delete.cli
Severity
ALERT
This message occurs when any inconsistency is found with the async delete trashbin directory of a volume.
Corrective Action
The "asynchronous directory delete from the client" feature has been disabled on this volume. To re-enable the feature, use the (privilege: advanced) "volume file async-delete client enable" command
Syslog Message
The "async directory delete from the client" feature was disabled in volume %s, after an inconsistency was detected with the trashbin directory.
volume (STRING): Name of the volume.
source (STRING): Location of the failing metadata validation.
Severity
NOTICE
This message occurs when any inconsistency is found with the preserve unlink trash directory of a volume.
Corrective Action
This message indicates that an inconsistency was found with preserve unlink trash directory. And hence disabling preserve unlink feature on this volume.
Syslog Message
Disabled preserve unlink feature in volume %s, after detecting inconsistency with trashbin directory.
