ONTAP EMS reference
fmmb.oldformatcleared events
fmmb.oldformatcleared EMS events occur when the older format HA mailboxes (special area of disk used for bookkeeping) are cleared on an upgrade from a pre 7.0 version of Data ONTAP to a 7.0 or later version.
fmmb.oldFormatCleared
Severity
INFORMATIONAL
This event is issued when the older format HA mailboxes (special area of disk used for bookkeeping) are cleared on an upgrade from a pre 7.0 version of Data ONTAP to a 7.0 or later version.
Corrective Action
(None).
Syslog Message
Clearing content of %s old format HA mailboxes (special area of disk used for bookkeeping).
whichone (STRING): Either local or partner to indicate which set of HA mailboxes are being cleared.
