The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fmmb.oldformatcleared events
Creating your file...
Your file is ready
fmmb.oldFormatCleared
- Severity
INFORMATIONAL
- Description
This event is issued when the older format HA mailboxes (special area of disk used for bookkeeping) are cleared on an upgrade from a pre 7.0 version of Data ONTAP to a 7.0 or later version.
- Corrective Action
(None).
- Syslog Message
Clearing content of %s old format HA mailboxes (special area of disk used for bookkeeping).
- Parameters
whichone (STRING): Either local or partner to indicate which set of HA mailboxes are being cleared.
