adt.stgvol events
adt.stgvol.info.notavailable
Severity
ERROR
This message occurs when retreiving staging volume information fails. This might be due to an internal system problem or the staging volume creation failed.
Corrective Action
Contact Cserver admin to check if staging volume has been created.
Syslog Message
Audit subsystem internal error: Either staging volume %s is not created or unable to retrieve staging volume information.
volName (STRING): The Name of the staging volume.
adt.stgvol.missing
Severity
ALERT
This message occurs when retrieving staging volume information fails. Either the staging volume was not created or information cannot be retrieved due to some internal error. As a result, auditing is not performed for operations on the corresponding volume.
Corrective Action
Use the command "vserver audit repair" in diagnostic mode to correct the problem.
Syslog Message
Audit subsystem internal error: Staging volume "%s" is either not created or not available.
volName (STRING): Name of the volume that is missing.
adt.stgvol.nospace
Severity
EMERGENCY
This message occurs when a staging volume does not have enough space and the audit service tries to create a new staging file or directory for writing audit logs.
Corrective Action
Check the volume for older staging files that are no longer required and remove those files. Then retry the operation.
Syslog Message
Audit subsystem internal error: Staging volume %s is full.
volName (STRING): Name of the volume that is full.
adt.stgvol.offline
Severity
EMERGENCY
This message occurs when a staging volume is offline and the audit service tries to write an audit log into the staging volume.
Corrective Action
Contact the Cserver administrator to set the staging volume status to online.
Syslog Message
Audit subsystem internal error: Staging volume %s is offline.
volName (STRING): The Name of the volume which is offline.
