adt.stgvol events
adt.stgvol.info.notavailable
- Severity
ERROR
 - Description
This message occurs when retreiving staging volume information fails. This might be due to an internal system problem or the staging volume creation failed.
 - Corrective Action
Contact Cserver admin to check if staging volume has been created.
 - Syslog Message
Audit subsystem internal error: Either staging volume %s is not created or unable to retrieve staging volume information.
 - Parameters
volName (STRING): The Name of the staging volume.
adt.stgvol.missing
- Severity
ALERT
 - Description
This message occurs when retrieving staging volume information fails. Either the staging volume was not created or information cannot be retrieved due to some internal error. As a result, auditing is not performed for operations on the corresponding volume.
 - Corrective Action
Use the command "vserver audit repair" in diagnostic mode to correct the problem.
 - Syslog Message
Audit subsystem internal error: Staging volume "%s" is either not created or not available.
 - Parameters
volName (STRING): Name of the volume that is missing.
adt.stgvol.nospace
- Severity
EMERGENCY
 - Description
This message occurs when a staging volume does not have enough space and the audit service tries to create a new staging file or directory for writing audit logs.
 - Corrective Action
Check the volume for older staging files that are no longer required and remove those files. Then retry the operation.
 - Syslog Message
Audit subsystem internal error: Staging volume %s is full.
 - Parameters
volName (STRING): Name of the volume that is full.
adt.stgvol.offline
- Severity
EMERGENCY
 - Description
This message occurs when a staging volume is offline and the audit service tries to write an audit log into the staging volume.
 - Corrective Action
Contact the Cserver administrator to set the staging volume status to online.
 - Syslog Message
Audit subsystem internal error: Staging volume %s is offline.
 - Parameters
volName (STRING): The Name of the volume which is offline.
