ONTAP EMS reference
scsiblade.prop events
scsiblade.prop.done.error
Severity
EMERGENCY
This message occurs when a CTRAN "proposal done" message is not received. The SAN management plane is inoperative for the Vserver until the corrective action is taken.
Corrective Action
For further information about correcting the problem, search the knowledgebase of the NetApp technical support support web site for the "scsiblade.prop.done.error" keyword.
Syslog Message
An internal error occurred in a %s group (MSID: %llu). The Vserver %s will not be able to process any management commands.
groupType (STRING): CTRAN group type.
volumeMSID (LONGINT): MSID of the volume in case the CTRAN group type is "volume"; otherwise, 0.
vserver (STRING): Name or UUID of the Vserver.
