configbr.backupfailed events
configbr.backupFailed
Severity
ALERT
This message occurs when when the configuration backup cannot be created.
Corrective Action
Verify the root volume file system is available and has enough space to create a backup with the "volume show" command. If the scheduled backup could not be created, create a backup file manually with the (privilege: advanced) "system configuration backup create" command, find the remote URL for uploading with the (privilege: advanced) "system configuration backup settings show -fields destination" command, and upload the backup with the (privilege: advanced) "system configuration backup upload" command.
Syslog Message
The %s configuration backup %s cannot be created. Error: '%s'.
type (STRING): Type of backup, either cluster or local.
backup (STRING): Backup file.
reason (STRING): Reason for the error.
