configbr.backupfailed events
Creating your file...
configbr.backupFailed
- Severity
ALERT
- Description
This message occurs when when the configuration backup cannot be created.
- Corrective Action
Verify the root volume file system is available and has enough space to create a backup with the "volume show" command. If the scheduled backup could not be created, create a backup file manually with the (privilege: advanced) "system configuration backup create" command, find the remote URL for uploading with the (privilege: advanced) "system configuration backup settings show -fields destination" command, and upload the backup with the (privilege: advanced) "system configuration backup upload" command.
- Syslog Message
The %s configuration backup %s cannot be created. Error: '%s'.
- Parameters
type (STRING): Type of backup, either cluster or local.
backup (STRING): Backup file.
reason (STRING): Reason for the error.
