The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.nfsv4poolthreshold events
Creating your file...
Your file is ready
Nblade.nfsV4PoolThreshold
- Severity
NOTICE
- Description
This message occurs when one of the NFSv4 store pools is nearing exhaustion (80% of max size). If the condition is allowed to continue, the store pool limits will be reached leading certain NFSv4 request failures.
- Corrective Action
Reduce NFSv4 workload like active opens, users and client connections which consume store pool objects to ensure their counts remain under pre-defined limits.
- Syslog Message
NFS Store Pool for %s is nearing exhaustion (%s of pool currently in use).
- Parameters
poolname (STRING): NFSv4 store pool type where the maximum limits are nearing.
percent (STRING): Percentage of store pool objects of type currently in use.
