nblade.nfsv4poolthreshold events
nblade.nfsv4poolthreshold EMS events occur when one of the NFSv4 store pools is nearing exhaustion (80% of max size).
Nblade.nfsV4PoolThreshold
- Severity
ERROR
- Description
This message occurs when one of the NFSv4 store pools is nearing exhaustion (80% of max size). If the condition is allowed to continue, the store pool limits will be reached leading certain NFSv4 request failures.
- Corrective Action
Reduce NFSv4 workload like active opens, users and client connections which consume store pool objects to ensure their counts remain under pre-defined limits.
- Syslog Message
NFS Store Pool for %s is nearing exhaustion (%s of pool currently in use).
- Parameters
poolname (STRING): NFSv4 store pool type where the maximum limits are nearing.
percent (STRING): Percentage of store pool objects of type currently in use.
