ONTAP EMS reference
nblade.nfsv4poolthreshold events
nblade.nfsv4poolthreshold EMS events occur when one of the NFSv4 store pools is nearing exhaustion (80% of max size).
Nblade.nfsV4PoolThreshold
Severity
NOTICE
This message occurs when one of the NFSv4 store pools is nearing exhaustion (80% of max size). If the condition is allowed to continue, the store pool limits will be reached leading certain NFSv4 request failures.
Corrective Action
Reduce NFSv4 workload like active opens, users and client connections which consume store pool objects to ensure their counts remain under pre-defined limits.
Syslog Message
NFS Store Pool for %s is nearing exhaustion (%s of pool currently in use).
poolname (STRING): NFSv4 store pool type where the maximum limits are nearing.
percent (STRING): Percentage of store pool objects of type currently in use.
