acp.fw events
acp.fw EMS events occur when ONTAP encounters issues associated with firmware download operations to the Alternate Control Path (ACP) Processor.
acp.fw.download
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Control Path (ACP) Processor receives a command to initiate a firmware download.
- Corrective Action
(None).
- Syslog Message
Firmware image %s will be downloaded to %s (%s), (disk shelf serial number: %s).
- Parameters
command (STRING): Firmware image name.
inband_id (STRING): In-band ID of the module.
ip (STRING): IP address of the module.
status (STRING): Status code returned by the 'initiation' command.
acp.fw.download.failed
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Controller Path Administrator fails in its attempt to download firmware.
- Corrective Action
(None).
- Syslog Message
Firmware download on %s (%s) failed with status (%s), (disk shelf serial number: %s).
- Parameters
status (STRING): Type of failure that occurred during the firmware download.
shelf_sno (STRING): Disk shelf serial number of the shelf where this I/O module is seated.
acp.fw.download.success
- Severity
INFORMATIONAL
- Description
This message occurs when a 'firmware download' command sent to the Alternate Controller Path Processor succeeds.
- Corrective Action
(None).
- Syslog Message
Firmware download on %s (%s) was successful, (disk shelf serial number: %s).
- Parameters
