acp.fw events
acp.fw.download
Severity
INFORMATIONAL
This message occurs when the Alternate Control Path (ACP) Processor receives a command to initiate a firmware download.
Corrective Action
(None).
Syslog Message
Firmware image %s will be downloaded to %s (%s), (disk shelf serial number: %s).
command (STRING): Firmware image name.
inband_id (STRING): In-band ID of the module.
ip (STRING): IP address of the module.
status (STRING): Status code returned by the 'initiation' command.
acp.fw.download.failed
Severity
INFORMATIONAL
This message occurs when the Alternate Controller Path Administrator fails in its attempt to download firmware.
Corrective Action
(None).
Syslog Message
Firmware download on %s (%s) failed with status (%s), (disk shelf serial number: %s).
status (STRING): Type of failure that occurred during the firmware download.
shelf_sno (STRING): Disk shelf serial number of the shelf where this I/O module is seated.
acp.fw.download.success
Severity
INFORMATIONAL
This message occurs when a 'firmware download' command sent to the Alternate Controller Path Processor succeeds.
Corrective Action
(None).
Syslog Message
Firmware download on %s (%s) was successful, (disk shelf serial number: %s).
