air.repaired events
air.repaired EMS events occur when ONTAP encounters issues associated with metadata inconsistencies that are automatically repaired immediately upon detection.
air.repaired.bucket.header
- Severity
NOTICE
- Description
This message occurs when ONTAP® discovers an inconsistency in a metadata bucket header record. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
TOC metadata (%s) has an inconsistent record for the bucket upload table (%s). %s.
- Parameters
toc_fh (STRING): File handle of the TOC metadata file.
upload_table_fh (STRING): File handle of the bucket upload table file.
state (STRING): Description of the metadata that was found to be inconsistent.
condition (STRING): Initial metadata validation test that failed.
source (STRING): Location of the failing metadata validation test.
air.repaired.cbmap
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the type/subtype of CloudBlockMap metafile. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
CloudBlockMap metafile %s certification failed: %s, %s (%s)
- Parameters
fh (STRING): File handle of the affected metafile.
condition (STRING): The initial metadata validation test that failed.
source (STRING): The location of the failing metadata validation test.
state (STRING): A description of the CloudBlockMap metafile that was found to be inconsistent.
air.repaired.cbmap.entry
- Severity
NOTICE
- Description
This message occurs when context mismatch is discovered in any entry of CloudBlockMap metafile. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
- Parameters
state (STRING): A description of the metafile that was found to be inconsistent.
pvbn (LONGINT): Inconsistency found in cbmap entry of this PVBN.
air.repaired.cbmap.header
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the header of CloudBlockMap metafile. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
- Parameters
air.repaired.chapter.entry
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in a metadata record. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Chapter metadata (%s) has inconsistent record for object (%s). Source %s (%s).
- Parameters
chapter_fh (STRING): File handle of the metadata file.
object_fh (STRING): File handle of the object.
air.repaired.dir.hole
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the hole list of a directory. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
Directory hole list %s certification failed: %s, %s.
- Parameters
fh (STRING): File handle of the affected directory.
air.repaired.dir.inode
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in a directory. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
Directory %s certification failed: %s, %s.
- Parameters
air.repaired.enc.vvol.info
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the encryptable aggregate metafile inodes encrypted flexvol information which stores vvol_btid and vvol_fid. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
Inode %s certification failed: %s, %s.
- Parameters
fh (STRING): File handle of the affected inode.
air.repaired.fabriclink
- Severity
NOTICE
- Description
This message occurs when a metadata inconsistency is discovered and repaired within an object storage replication data structure.
- Corrective Action
(None).
- Syslog Message
AIR repaired %s, condition %s at %s, object "%s"
- Parameters
fh (STRING): File handle of the replication data structure that was found to be inconsitent.
expr (STRING): The nature of the inconsistency that was discovered and repaired.
source (STRING): Location where the metadata inconsistency was detected.
object (STRING): Optionally represents the name of a particular object whose replication state was affected.
air.repaired.fc.dir
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in any directory in the volume. The inconsistency is repaired automatically as soon as it is discovered.
- Corrective Action
(None).
- Syslog Message
Evicted inconsistent directory with fh %s due to corruption in volume %s.
- Parameters
volume (STRING): Name of the volume.
air.repaired.fc.qtree.id
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the qtree ID of an inode. The inconsistent inode is evicted automatically as soon as it is discovered.
- Corrective Action
(None).
- Syslog Message
Evicted inconsistent inode with fh %s due to a corrupted qtree ID: qtree ID %d, volume %s.
- Parameters
tid (INT): Qtree ID.
air.repaired.hardlink.i2p
- Severity
NOTICE
- Description
This message occurs when the AIR subsystem repairs an inconsistent inode and previously unreachable hard links are returned to availability.
- Corrective Action
(None).
- Syslog Message
AIR repaired inconsistent hardlink for inode %d: %d %d %s
- Parameters
inode (INT): Inode number.
parent_inode (INT): Parent inode number.
link_count (INT): Inode link count.
air.repaired.label.database
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered within a WAFL label database. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Label database %s certification failed: %s, %s (%s)
- Parameters
state (STRING): A description of the metadata that was found to be inconsistent.
air.repaired.lsm.bfc.lkp
- Severity
NOTICE
- Description
This message occurs when the system detects an inconsistency in the LSM BFC Lookup file. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
LSM BFC Lookup file %s was corrected at block %d. Source %s.
- Parameters
fh (STRING): File handle of the affected file.
block (LONGINT): Block number of the inconsistent block.
air.repaired.lsm.bloom.file
- Severity
NOTICE
- Description
This message occurs when the system detects an inconsistency in the LSM Bloomfilter file. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
LSM Bloomfilter file %s was corrected at block %d. Source %s.
- Parameters
air.repaired.lsm.info.file
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the LSM Info file. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
LSM Info file %s was corrected at block %d. Source %s.
- Parameters
block (INT): Block number of the inconsistent block.
air.repaired.lsm.keyspc.file
- Severity
NOTICE
- Description
This message occurs when the system detects an inconsistency in the LSM Keyspace Information file. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
Inconsistent LSM Keyspace Information metafile on aggregate "%s" was repaired. Source %s.
- Parameters
aggregate (STRING): Name of the aggregate.
air.repaired.lsm.lookup.file
- Severity
NOTICE
- Description
This message occurs when the system detects an inconsistency in the LSM Lookup file. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
LSM Lookup file %s was corrected at block %d. Source %s.
- Parameters
air.repaired.merkle
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the metadata (Merkle tree file). Repairs to the Merkle tree file have automatically been started.
- Corrective Action
(None).
- Syslog Message
Merkle file "%s" certification failed: %s, directory ID (%llu), branch ID (%llu), buffer level %d, fbn (%llu), Merkle tree level (%d)
- Parameters
fh (STRING): File handle of the Merkle file that needs repairs.
condition (STRING): Initial validation test that failed.
dir_id (LONGINT): Slice directory ID of the Merkle file.
branch_id (LONGINT): Slice branch ID of the Merkle file.
level (INT): Buffer level of the Merkle file block.
fbn (LONGINT): File block number (FBN) of the Merkle file.
merkle_level (INT): Merkle checksum level of the Merkle file.
source (STRING): The location of the failing validation test.
air.repaired.mpu.catalog
- Severity
NOTICE
- Description
This message occurs when ONTAP® discovers an inconsistency in a multipart upload catalog record of a bucket upload table. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Bucket upload table (%s) has an inconsistent record for the multipart upload catalog (%s). %s.
- Parameters
mp_catalog_fh (STRING): File handle of the multipart catalog file.
air.repaired.name.info.flags
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the name information flags of a directory. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
Name information flags for directory entry %s corrected at block %d and index %d. Source %s.
- Parameters
block (INT): Block number that contains the affected entry
index (INT): Location within the block that holds the affected entry
air.repaired.pct.entry
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
PCT metadata has inconsistent record for bucket (%u) file (%u). Source %s (%s, %s).
- Parameters
bucketid (INT): Bucket identifier.
fileid (INT): File identifier.
air.repaired.qtree.id
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the qtree ID of an inode. The inconsistency is repaired automatically as soon as it is discovered.
- Corrective Action
(None).
- Syslog Message
Repaired inconsistent inode with fh %s due to a corrupted qtree ID: Old qtree ID %d, new qtree ID %d, volume %s.
- Parameters
old_tid (INT): Old qtree ID.
new_tid (INT): New qtree ID.
air.repaired.qtree.metafile
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in a qtree metafile.The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
Qtree metafile %s
- Parameters
details (STRING): Description of the metadata failure that has been fixed.
air.repaired.qtree.root
- Severity
NOTICE
- Description
This message occurs when the system discovers an inconsistency between the qtree file root and a qtree metafile entry. The system repairs this inconsistency automatically, as soon as it detects it.
- Corrective Action
(None).
- Syslog Message
Qtree root %s certification failed: %s, %s corrections: %s.
- Parameters
fh (STRING): File handle of the affected qtree root.
state (STRING): Description of the metadata that has been fixed.
air.repaired.rclone.database
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered within the WAFL Remote Clone Database. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Remote Clone Database %s certification failed: %s, %s (%s)
- Parameters
air.repaired.rclone.record
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in any record of the WAFL Remote Clone Database. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Remote Clone Record %s certification failed: %s, %s (%s)
- Parameters
fh (STRING): File handle of the affected record.
condition (STRING): The initial record validation test that failed.
source (STRING): The location of the failing record validation test.
state (STRING): A description of the entry that was found to be inconsistent.
air.repaired.remote.index
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered within the WAFL RAL index. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Remote index %s certification failed: %s, %s (%s)
- Parameters
state (STRING): The RAL index record that was discovered to be incorrect.
air.repaired.remote.inode
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered between a file and its RAL state within WAFL. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Remote inode %s certification failed: %s, %s (%s)
- Parameters
state (STRING): A description of the RAL state metadata that was found to be inconsistent.
air.repaired.remote.metafile
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered within a WAFL RAL metafile. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Remote metafile %s certification failed: %s, %s (%s)
- Parameters
state (STRING): A description of the RAL metafile that was found to be inconsistent.
air.repaired.remote.tallies
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the tallies in Remote Entry metafile. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
- Parameters
air.repaired.rlem.tallies
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the tallies in Remote Lock Entry metafile(RLEM). The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Remote lock entry metafile %s certification failed: %s, %s (%s)
- Parameters
rlem (STRING): Describes the metafile to which this lock entry belongs to.
state (STRING): A description of the RLEM that was found to be inconsistent.
air.repaired.slice
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in the metadata (slice file). Repairs to the slice file from the secondary copy have automatically been started.
- Corrective Action
(None).
- Syslog Message
Slice file "%s" certification failed: %s, dir ID (%llu), branch ID (%llu), level %d, fbn (%llu)
- Parameters
fh (STRING): File handle of the slice file that needs repairs.
condition (STRING): The initial validation test that failed.
dir_id (LONGINT): Slice directory ID of the slice file.
branch_id (LONGINT): Slice branch ID of the slice file.
level (INT): Buffer level of the slice file block.
fbn (LONGINT): File block number (FBN) of the slice file.
air.repaired.snapinfo.block
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in a Snapinfo metafile block. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
Repaired inconsistent block (%s) found in Snapinfo metafile on volume "%s".
- Parameters
state (STRING): Description of the Snapinfo metafile block that was found to be inconsistent.
air.repaired.ssm.iftp.inode
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered in ssm iftp metafile. The inconsistency is repaired automatically as soon as it is detected.
- Corrective Action
(None).
- Syslog Message
AIR vlist metafile %s certification failed: %s, %s.
- Parameters
air.repaired.toc.entry
- Severity
ALERT
- Description
This message occurs when an inconsistency is discovered in a metadata record. The inconsistency is automatically repaired immediately upon detection. But it can leave behind lost objects that are no longer pointed to by the namespace.
- Corrective Action
The command "object-store-server lost-object-recovery start" under diag privilege can be used to add lost objects back into namespace. The progress of this command can be monitored using "object-store-server lost-object-recovery show" command.
- Syslog Message
TOC metadata (%s) has inconsistent record for chapter (%s). %s (%s).
- Parameters
chapter_fh (STRING): File handle of the chapter metadata file.
air.repaired.user.ind
- Severity
ERROR
- Description
This message occurs when an inconsistency is discovered in the user indirect block. The inconsistency is repaired automatically immediately upon detection.
- Corrective Action
(None).
- Syslog Message
User indirect %s certification failed: %s (%s)
- Parameters
state (STRING): Description of the user indirect block that was found to be inconsistent.
air.repaired.vplus
- Severity
NOTICE
- Description
This message occurs when an indexed storage tree is rebuilt to repair a metadata inconsistency that was discovered.
- Corrective Action
(None).
- Syslog Message
AIR vplus rebuild of %s completed for subtype %d
- Parameters
fh (STRING): File handle of the storage tree.
subtype (INT): Subtype of the inode encountering the inconsistency.
