ONTAP EMS reference
air.repaired events
air.repaired.bucket.header
Severity
NOTICE
This message occurs when ONTAP® discovers an inconsistency in a metadata bucket header record. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
TOC metadata (%s) has an inconsistent record for the bucket upload table (%s). %s.
toc_fh (STRING): File handle of the TOC metadata file.
upload_table_fh (STRING): File handle of the bucket upload table file.
state (STRING): Description of the metadata that was found to be inconsistent.
condition (STRING): Initial metadata validation test that failed.
source (STRING): Location of the failing metadata validation test.
air.repaired.cbmap
Severity
NOTICE
This message occurs when an inconsistency is discovered in the type/subtype of CloudBlockMap metafile. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
CloudBlockMap metafile %s certification failed: %s, %s (%s)
fh (STRING): File handle of the affected metafile.
condition (STRING): The initial metadata validation test that failed.
source (STRING): The location of the failing metadata validation test.
state (STRING): A description of the CloudBlockMap metafile that was found to be inconsistent.
air.repaired.cbmap.entry
Severity
NOTICE
This message occurs when context mismatch is discovered in any entry of CloudBlockMap metafile. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
state (STRING): A description of the metafile that was found to be inconsistent.
pvbn (LONGINT): Inconsistency found in cbmap entry of this PVBN.
air.repaired.cbmap.header
Severity
NOTICE
This message occurs when an inconsistency is discovered in the header of CloudBlockMap metafile. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
air.repaired.chapter.entry
Severity
NOTICE
This message occurs when an inconsistency is discovered in a metadata record. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Chapter metadata (%s) has inconsistent record for object (%s). Source %s (%s).
chapter_fh (STRING): File handle of the metadata file.
object_fh (STRING): File handle of the object.
air.repaired.cssSnapdbFh
Severity
NOTICE
Corrective Action
(None).
Syslog Message
Inconsistency in the css snapdb filehandle information of the TOC metadata %s belonging to bucket %u is being repaired.
toc_fh (STRING): File handle of the TOC metafile.
bucket_num (INT): Bucket number.
air.repaired.cssSnapdbHdr
Severity
NOTICE
This message occurs when ONTAP® discovers an inconsistency in the user header of the css snapdb metafile. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Inconsistency in user header of css snapdb metafile %s belonging to bucket %u is being repaired.
snapdb_fh (STRING): File handle of the snapdb metafile.
air.repaired.cssSnapdbInode
Severity
NOTICE
This message occurs when ONTAP® discovers an inconsistency in the css snapdb metafile inode. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Inconsistency in the css snapdb inode information of the TOC metadata %s belonging to bucket %u is being repaired.
air.repaired.cssSnapdbTid
Severity
NOTICE
This message occurs when ONTAP® discovers an inconsistency in the qtree id of the css snapdb metafile inode. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Inconsistency in the TID of the css snapdb metafile inode %s belonging to bucket %u is being repaired.
air.repaired.dir.hole
Severity
NOTICE
This message occurs when an inconsistency is discovered in the hole list of a directory. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
Directory hole list %s certification failed: %s, %s.
fh (STRING): File handle of the affected directory.
air.repaired.dir.inode
Severity
NOTICE
This message occurs when an inconsistency is discovered in a directory. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
Directory %s certification failed: %s, %s.
air.repaired.enc.vvol.info
Severity
NOTICE
This message occurs when an inconsistency is discovered in the encryptable aggregate metafile inodes encrypted flexvol information which stores vvol_btid and vvol_fid. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
Inode %s certification failed: %s, %s.
fh (STRING): File handle of the affected inode.
Severity
NOTICE
This message occurs when a metadata inconsistency is discovered and repaired within an object storage replication data structure.
Corrective Action
(None).
Syslog Message
AIR repaired %s, condition %s at %s, object "%s"
fh (STRING): File handle of the replication data structure that was found to be inconsitent.
expr (STRING): The nature of the inconsistency that was discovered and repaired.
source (STRING): Location where the metadata inconsistency was detected.
object (STRING): Optionally represents the name of a particular object whose replication state was affected.
air.repaired.fc.dir
Severity
NOTICE
This message occurs when an inconsistency is discovered in any directory in the volume. The inconsistency is repaired automatically as soon as it is discovered.
Corrective Action
(None).
Syslog Message
Evicted inconsistent directory with fh %s due to corruption in volume %s.
volume (STRING): Name of the volume.
air.repaired.fc.qtree.id
Severity
NOTICE
This message occurs when an inconsistency is discovered in the qtree ID of an inode. The inconsistent inode is evicted automatically as soon as it is discovered.
Corrective Action
(None).
Syslog Message
Evicted inconsistent inode with fh %s due to a corrupted qtree ID: qtree ID %d, volume %s.
tid (INT): Qtree ID.
Severity
NOTICE
This message occurs when the AIR subsystem repairs an inconsistent inode and previously unreachable hard links are returned to availability.
Corrective Action
(None).
Syslog Message
AIR repaired inconsistent hardlink for inode %d: %d %d %s
inode (INT): Inode number.
parent_inode (INT): Parent inode number.
link_count (INT): Inode link count.
air.repaired.label.database
Severity
NOTICE
This message occurs when an inconsistency is discovered within a WAFL label database. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Label database %s certification failed: %s, %s (%s)
state (STRING): A description of the metadata that was found to be inconsistent.
air.repaired.lsm.bfc.lkp
Severity
NOTICE
This message occurs when the system detects an inconsistency in the LSM BFC Lookup file. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
LSM BFC Lookup file %s was corrected at block %d. Source %s.
fh (STRING): File handle of the affected file.
block (LONGINT): Block number of the inconsistent block.
air.repaired.lsm.bloom.file
Severity
NOTICE
This message occurs when the system detects an inconsistency in the LSM Bloomfilter file. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
LSM Bloomfilter file %s was corrected at block %d. Source %s.
air.repaired.lsm.info.file
Severity
NOTICE
This message occurs when an inconsistency is discovered in the LSM Info file. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
LSM Info file %s was corrected at block %d. Source %s.
block (INT): Block number of the inconsistent block.
air.repaired.lsm.keyspc.file
Severity
NOTICE
This message occurs when the system detects an inconsistency in the LSM Keyspace Information file. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
Inconsistent LSM Keyspace Information metafile on aggregate "%s" was repaired. Source %s.
aggregate (STRING): Name of the aggregate.
air.repaired.lsm.lookup.file
Severity
NOTICE
This message occurs when the system detects an inconsistency in the LSM Lookup file. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
LSM Lookup file %s was corrected at block %d. Source %s.
air.repaired.merkle
Severity
NOTICE
This message occurs when an inconsistency is discovered in the metadata (Merkle tree file). Repairs to the Merkle tree file have automatically been started.
Corrective Action
(None).
Syslog Message
Merkle file "%s" certification failed: %s, directory ID (%llu), branch ID (%llu), buffer level %d, fbn (%llu), Merkle tree level (%d)
fh (STRING): File handle of the Merkle file that needs repairs.
condition (STRING): Initial validation test that failed.
dir_id (LONGINT): Slice directory ID of the Merkle file.
branch_id (LONGINT): Slice branch ID of the Merkle file.
level (INT): Buffer level of the Merkle file block.
fbn (LONGINT): File block number (FBN) of the Merkle file.
merkle_level (INT): Merkle checksum level of the Merkle file.
source (STRING): The location of the failing validation test.
air.repaired.mpu.catalog
Severity
NOTICE
This message occurs when ONTAP® discovers an inconsistency in a multipart upload catalog record of a bucket upload table. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Bucket upload table (%s) has an inconsistent record for the multipart upload catalog (%s). %s.
mp_catalog_fh (STRING): File handle of the multipart catalog file.
air.repaired.multipart.database
Severity
NOTICE
This message occurs when an inconsistency is discovered in the metadata of a multipart inode. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Multipart inode %s certification failed: %s, %s (%s)
condition (STRING): The database validation test that failed.
source (STRING): The location of the failing database validation test.
air.repaired.multipart.inode
Severity
NOTICE
This message occurs when an inconsistency is discovered in a multipart inode. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
condition (STRING): The initial multipart inode validation test that failed.
source (STRING): The location of the failing multipart inode validation test.
air.repaired.multipart.record
Severity
NOTICE
This message occurs when an inconsistency is discovered in the metadata of the multipart inode. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
condition (STRING): The initial record validation test that failed.
source (STRING): The location of the failing record validation test.
state (STRING): A description of the record that was found to be inconsistent.
air.repaired.multipart.rectify
Severity
NOTICE
This message occurs when an inconsistency is discovered in the rectification metadata for a multipart file. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
air.repaired.multipart.userheader
Severity
NOTICE
This message occurs when an inconsistency is discovered in the userheader section of a multipart file. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Multipart inode %s userheader certification failed: %s, %s
condition (STRING): The initial userheader validation test that failed.
source (STRING): The location of the failing userheader validation test.
air.repaired.name.info.flags
Severity
NOTICE
This message occurs when an inconsistency is discovered in the name information flags of a directory. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
Name information flags for directory entry %s corrected at block %d and index %d. Source %s.
block (INT): Block number that contains the affected entry
index (INT): Location within the block that holds the affected entry
air.repaired.pct.entry
Severity
NOTICE
Corrective Action
(None).
Syslog Message
PCT metadata has inconsistent record for bucket (%u) file (%u). Source %s (%s, %s).
bucketid (INT): Bucket identifier.
fileid (INT): File identifier.
air.repaired.qtree.id
Severity
NOTICE
This message occurs when an inconsistency is discovered in the qtree ID of an inode. The inconsistency is repaired automatically as soon as it is discovered.
Corrective Action
(None).
Syslog Message
Repaired inconsistent inode with fh %s due to a corrupted qtree ID: Old qtree ID %d, new qtree ID %d, volume %s.
old_tid (INT): Old qtree ID.
new_tid (INT): New qtree ID.
air.repaired.qtree.metafile
Severity
NOTICE
This message occurs when an inconsistency is discovered in a qtree metafile.The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
Qtree metafile %s
details (STRING): Description of the metadata failure that has been fixed.
air.repaired.qtree.root
Severity
NOTICE
This message occurs when the system discovers an inconsistency between the qtree file root and a qtree metafile entry. The system repairs this inconsistency automatically, as soon as it detects it.
Corrective Action
(None).
Syslog Message
Qtree root %s certification failed: %s, %s corrections: %s.
fh (STRING): File handle of the affected qtree root.
state (STRING): Description of the metadata that has been fixed.
air.repaired.ral.clone.exp
Severity
NOTICE
This message occurs when an inconsistency is discovered between the source, clone created via ral retrieve and the clone expansion structure in source's remote state.
Corrective Action
(None).
Syslog Message
Remote RAL Clone %s certification failed: %s, %s (%s)
fh (STRING): File handle of the affected clone.
state (STRING): A description of the source and clone files.
air.repaired.rclone.database
Severity
NOTICE
This message occurs when an inconsistency is discovered within the WAFL Remote Clone Database. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote Clone Database %s certification failed: %s, %s (%s)
air.repaired.rclone.record
Severity
NOTICE
This message occurs when an inconsistency is discovered in any record of the WAFL Remote Clone Database. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote Clone Record %s certification failed: %s, %s (%s)
fh (STRING): File handle of the affected record.
state (STRING): A description of the entry that was found to be inconsistent.
air.repaired.remote.index
Severity
NOTICE
This message occurs when an inconsistency is discovered within the WAFL RAL index. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote index %s certification failed: %s, %s (%s)
state (STRING): The RAL index record that was discovered to be incorrect.
air.repaired.remote.inode
Severity
NOTICE
This message occurs when an inconsistency is discovered between a file and its RAL state within WAFL. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote inode %s certification failed: %s, %s (%s)
state (STRING): A description of the RAL state metadata that was found to be inconsistent.
air.repaired.remote.metafile
Severity
NOTICE
This message occurs when an inconsistency is discovered within a WAFL RAL metafile. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote metafile %s certification failed: %s, %s (%s)
state (STRING): A description of the RAL metafile that was found to be inconsistent.
air.repaired.remote.tallies
Severity
NOTICE
This message occurs when an inconsistency is discovered in the tallies in Remote Entry metafile. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
air.repaired.remote.writeback.dirtylist.record
Severity
NOTICE
This message occurs when an inconsistency is discovered between a file and its writeback metadata within WAFL. The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote inode %s writeback certification failed: %s, %s (%s)
state (STRING): A description of the writeback metadata that was found to be inconsistent.
air.repaired.rlem.tallies
Severity
NOTICE
This message occurs when an inconsistency is discovered in the tallies in Remote Lock Entry metafile(RLEM). The inconsistency is automatically repaired immediately upon detection.
Corrective Action
(None).
Syslog Message
Remote lock entry metafile %s certification failed: %s, %s (%s)
rlem (STRING): Describes the metafile to which this lock entry belongs to.
state (STRING): A description of the RLEM that was found to be inconsistent.
air.repaired.slice
Severity
NOTICE
This message occurs when an inconsistency is discovered in the metadata (slice file). Repairs to the slice file from the secondary copy have automatically been started.
Corrective Action
(None).
Syslog Message
Slice file "%s" certification failed: %s, dir ID (%llu), branch ID (%llu), level %d, fbn (%llu)
fh (STRING): File handle of the slice file that needs repairs.
condition (STRING): The initial validation test that failed.
dir_id (LONGINT): Slice directory ID of the slice file.
branch_id (LONGINT): Slice branch ID of the slice file.
level (INT): Buffer level of the slice file block.
fbn (LONGINT): File block number (FBN) of the slice file.
air.repaired.snapinfo.block
Severity
NOTICE
This message occurs when the system detects an inconsistency in the persistent lock entry metafile. The inconsistent entry has been removed.
Corrective Action
(None).
Syslog Message
Repaired inconsistent block (%s) found in Snapinfo metafile on volume "%s".
state (STRING): Description of the Snapinfo metafile block that was found to be inconsistent.
air.repaired.ssm.iftp.inode
Severity
NOTICE
This message occurs when an inconsistency is discovered in ssm iftp metafile. The inconsistency is repaired automatically as soon as it is detected.
Corrective Action
(None).
Syslog Message
AIR vlist metafile %s certification failed: %s, %s.
air.repaired.toc.entry
Severity
ALERT
This message occurs when an inconsistency is discovered in a metadata record. The inconsistency is automatically repaired immediately upon detection. But it can leave behind lost objects that are no longer pointed to by the namespace.
Corrective Action
The command "object-store-server lost-object-recovery start" under diag privilege can be used to add lost objects back into namespace. The progress of this command can be monitored using "object-store-server lost-object-recovery show" command.
Syslog Message
TOC metadata (%s) has inconsistent record for chapter (%s). %s (%s).
chapter_fh (STRING): File handle of the chapter metadata file.
air.repaired.user.ind
Severity
ERROR
This message occurs when an inconsistency is discovered in the user indirect block. The inconsistency is repaired automatically immediately upon detection.
Corrective Action
(None).
Syslog Message
User indirect %s certification failed: %s (%s)
state (STRING): Description of the user indirect block that was found to be inconsistent.
air.repaired.vplus
Severity
NOTICE
This message occurs when an indexed storage tree is rebuilt to repair a metadata inconsistency that was discovered.
Corrective Action
(None).
Syslog Message
AIR vplus rebuild of %s completed for subtype %d
fh (STRING): File handle of the storage tree.
subtype (INT): Subtype of the inode encountering the inconsistency.
