ONTAP EMS reference
mcc.auso events
mcc.auso.trigFailed
Severity
EMERGENCY
This message occurs when a trigger for automatic unplanned switchover fails to issue the operation.
Corrective Action
Verify the health of each node and that automatic unplanned switchover is enabled on both by using the "metrocluster node show" command. Use the "metrocluster switchover -forced-on-disaster true" command to switch over the DR-site storage manually.
Syslog Message
A trigger for Automatic Unplanned Switchover failed to issue the operation. Reason: %s.
probableCauseDescription (STRING): Further description of the probable cause.
alertId (STRING): Identifier for this condition.
alertingResource (STRING): Unique name of the resource responsible for this condition.
alertingResourceName (STRING): Name of the resource responsible for this condition.
possibleEffect (STRING): Possible effect of the failure.
probableCause (STRING): Probable cause of the failure.
additionalInfo (STRING): Additional information about this failure.
mcc.auso.triggered
Severity
NOTICE
This message occurs when the node triggers an automatic unplanned switchover on detection of a failure of the DR partner node.
Corrective Action
(None).
Syslog Message
The node has triggered an Automatic Unplanned Switchover of the DR partner. Reason: %s. If Automatic Unplanned Switchover was triggered because of heartbeat loss, any ongoing dump on the partner may be aborted.
cause (STRING): Cause for triggering automatic unplanned switchover.
