The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
acp.bind events
Creating your file...
Your file is ready
acp.bind.error
- Severity
ERROR
- Description
This message occurs when the system encounters a socket binding error while setting up the Alternate Control Path (ACP) Management Ethernet port. ACP functionality is inactive after encountering this.
- Corrective Action
Verify that the Ethernet cable is properly attached to the ACP port and the green LED is on. Reenable the ACP port using the "options acp.enabled" command.
- Syslog Message
An error was encountered while configuring the ACP Management Ethernet Port: %s.
- Parameters
ErrorString (STRING): Error string.
