acp.bind events
Creating your file...
Your file is ready
acp.bind.error
- Severity
ERROR
- Description
This message occurs when the system encounters a socket binding error while setting up the Alternate Control Path (ACP) Management Ethernet port. ACP functionality is inactive after encountering this.
- Corrective Action
Verify that the Ethernet cable is properly attached to the ACP port and the green LED is on. Reenable the ACP port using the "options acp.enabled" command.
- Syslog Message
An error was encountered while configuring the ACP Management Ethernet Port: %s.
- Parameters
ErrorString (STRING): Error string.
